wiseman73
Nov 23, 2022Aspirant
Xr1000 keeps losing all internet connection
im having this same problem. did this ever get resolved??
wiseman73
I did everything you’re talking about . It has stayed with the “ Nov 23 17:09:17 oasis user.warn com.netdumasiftware.desktop: Congo write ‘com.netdumasoftware.desktop.database’ 118 “
Nov 25, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What browser are you using?
After the reset and you walk thru the set up wizard, change the default DHCP IP address pool range to .100 to .200. Save and apply and reboot the router.
