westk
Sep 07, 2023Aspirant
XR1000 latency issues
Hello, seems I´m out of support so I have to post here to help any help with my Netgear product. Ok, I have a XR1000 with the latest firmware and lately is getting weird. When I use my phone connecte...
- Oct 22, 2023
Read the thread then. I already did that you have been saying.
Also, the issue is no longer there now. I have to change the channel to 161. I do not know how a 300usd equipment cannot handle this things automatically.
Netduma-Fraser
Sep 08, 2023NetDuma Partner
This is what QoS is designed to prevent happening, how have you setup QoS exactly? Could you provide a screenshot of the QoS page?
- westkSep 08, 2023Aspirant
Thanks for reply. But this is not a QoS issue. I´ve never turn it on and always worked "fine". Now if the mobile is consuming 14 Mbps and have this rage latency issue for many seconds. I have 300 Mbps available. Is not a bufferbloat issue.
Also, the router is not getting the real IP for each device, so, I have 2 devices connected but the router just see 1. This issue, not like the original, always happened. Its a shame that 300 bucks router cannot be able to determine which devices are connected to it.
- Netduma-FraserSep 08, 2023NetDuma PartnerThere is no other reason I can think of why one device using the internet causes another to lag other than that, could you try it to see if it does help?
Is there an unnamed device on the Device Manager that shares the IP of the device?- westkSep 08, 2023Aspirant
The network benchmark is not working as well the autosetup of QoS. I will put it as manual and see if it helps.
No, the Device Manager shows the devices and when you want to see the device info, appear like it has multiple IP.
