westk
Sep 08, 2023Aspirant
XR1000 latency issues
Hello, seems I´m out of support so I have to post here to help any help with my Netgear product. Ok, I have a XR1000 with the latest firmware and lately is getting weird. When I use my phone connecte...
- Oct 22, 2023
Read the thread then. I already did that you have been saying.
Also, the issue is no longer there now. I have to change the channel to 161. I do not know how a 300usd equipment cannot handle this things automatically.
Netduma-Fraser
Oct 21, 2023NetDuma Partner
Use Always and start with 70% for both download/upload, see if the same issue occurs, if it does move it down by 5% and check again, keep doing that until you get values that prevent it happening.
westk
Oct 21, 2023Aspirant
Let see.. 5 Mbps over 300 Mbps is not a bandwidth issue. Period. Thanks for passing by anyways.
- Netduma-FraserOct 22, 2023NetDuma PartnerI'm not sure what you mean, I'm not saying you have a bandwidth issue, I'm saying you have an issue that QoS can resolve, by reducing the sliders by 5% increments and checking whether you get the issue you can eventually find the percentage that works best for you to prevent it. I am trying to help, if you no longer want it, just say, there is no need to be rude.
- westkOct 22, 2023Aspirant
- FURRYe38Oct 24, 2023Guru - Experienced User
5Ghz WiFi spec doesn't support automatic channel selection.
