bobbydigital00
Aug 21, 2023Apprentice
XR1000 Latest Firmware VPN users unable to connect
Hello World, I have a strange issue. I have a firewall that users connect to via VPN and I have a XR1000 connected to a port off the firewall with the XR1000 in AP mode. I have several RFC1918 ne...
Netduma-Fraser
Aug 21, 2023NetDuma Partner
In AP mode DumaOS is disabled so may be best to compare the settings you have on the R7800 and see what is different on the 1000 and go from there
- bobbydigital00Aug 21, 2023Apprentice
Thank You For Your Response.
I checked all the settings. They are basically the same. Once you put the router in AP mode not a lot of options are present.
Are certain routing protocols disabled when DumaOS is disabled or does it just become a layer 3 device at that point. The only difference with one working and one not working is the OS that is running on the routers.
- Netduma-FraserAug 21, 2023NetDuma PartnerYeah they basically run the same as far as I know, maybe FURRYe38 has a suggestion?
- FURRYe38Aug 22, 2023Guru - Experienced User
How are the R7800 an XR1000 configured for AP mode? Auto DHCP or Static IP addressed on each router?
Ya, AP mode, would just be working to just pass through data traffic too and from. All normal router features and functions are disabled awhile in AP mode sans Wifi configurations. Should not be blocking anything.
Does the VPN or firewall device show logs for when this happens when the XR router is connected?
What is the brand and model# of this firewall?
What is the Mfr and model# of the Internet Service Providers modem/ONT the firewall is connected too?
