Xr1000FTW
Feb 26, 2024Aspirant
xr1000 latest patch ethernet drops
since the newest patch couple days ago ive experienced 2 ethernet drops wifi still works
Netduma-Fraser
Feb 27, 2024NetDuma Partner
It was just a security update so nothing else has changed, may be worth a factory reset depending on the last time you did one - I generally recommend doing it after every update
Xr1000FTW
Feb 27, 2024Aspirant
the patch before this 1 been working fine until i did this 1 current fix is i switched ethernet port but never had this issue before
