Xr1000FTW
Feb 26, 2024Aspirant
xr1000 latest patch ethernet drops
since the newest patch couple days ago ive experienced 2 ethernet drops wifi still works
Xr1000FTW
Feb 27, 2024Aspirant
the patch before this 1 been working fine until i did this 1 current fix is i switched ethernet port but never had this issue before
Netduma-Fraser
Feb 27, 2024NetDuma Partner
In LAN Settings, set the DHCP range to start at .50, then assign reserved IP addresses to devices between .2 & .49 so they're out of the DHCP range, apply, reboot from the interface, wait 4 minutes and see if that stops the disconnects.
