Lanners
Jul 23, 2023Follower
XR1000 MetroNet
Has anyone by chance successfully got their XR1000 to work with MetroNet? I currently have the 2gbps fiber. In order for me to get it to work I have to set it to either bridge mode or wireless AP con...
Netduma-Fraser
Jul 24, 2023NetDuma Partner
Do you know if you require PPPoE, VLAN or DHCP identifiers to get a connection? If you're not sure check the Eero internet settings. If you do you'll need to put those in the XR before you can get internet. Otherwise you may just need to reboot the Nokia, wait 2 minutes, reboot the XR, wait 2 minutes then check.
Jul 24, 2023Guru - Experienced User
Also the XR1000 isn't supporting of 2Gb ISP speed due to the WAN and LAN ports being 1000Mbps max capable.
If you want to see anything near 2Gb, you'll need a different router.
Netgears Orbi 9 series and the upcoming RS700 both have 10Gb WAN ports. Orbi has 2.5Gb LAN port and the RS is reported to have 10Gb LAN ports.
