OfficialJulio
Dec 19, 2020Aspirant
XR1000 Moderate Nat
I've been having issues making my nat type open and haven't been succesful. I've open UpNp I have also opened nat filtering thinking maybe it would help but hasn't. Is there anything else that i coul...
Dec 20, 2020Guru - Experienced User
what modem is it connected to?
You should be set NAT to open under your wan settings.
What device are you connecting to it for nat?
- OfficialJulioDec 20, 2020AspirantI have it connected to a CenturyLink modem. My nat is set to open under my wan setting. I am connecting it to a PlayStation 4.
- plemansDec 20, 2020Guru - Experienced User
What centurylink modem?
many of them have their own integrated routers. Which can cause nat issues - D-MEADJan 19, 2021TutorIf you haven't solved this problem yet, you will have to have your modem Bridged. To do this call your ISP (Centurylink) argue with them until they help you bridge it. Then set your router back to using UPNP. Hope this helps.
