Farhad47
Apr 12, 2022Aspirant
XR1000 NAT type always moderate
Hi i just got the XR1000 but cant get my NAT type open on anything its always moderate i have tried WAN open from secured UpNP enabled/disabled Upnp disabled with manual port fowarding for Warzone but...
Farhad47
Hi i have tried the test its ping 30x but it says the first line with <1ms <1ms <1ms (then my ip)
But the other 29 says * * * instead of 1ms and then (request timed out.) under my ip is this cg nat?
Netduma-Liam
Apr 13, 2022NetDuma Partner
Are you connected directly to your ISP router/modem when doing this?
Can you google 'What's my IP' again and double check that the IP google returns is the same as the one you're running traceroute against?
If you purchase a static IP from your ISP, you shouldn't need to make and modifications in the XR1000 settings.
- Farhad47Apr 13, 2022AspirantYes i am ethernet and it says same thing first line is like this
1 <1ms <1ms <1ms 192.168.1
2 * * * request timed out.
3 * * * request timed out.
4 * * * request timed out.
It goes on like this for 30 lines - Farhad47Apr 13, 2022AspirantAlso i dont have a isp router/modem as i am using nighthawk xr1000 which is connected to a Fibre ONT on the wall which is conected from VLAN ID to my service
- FURRYe38Apr 13, 2022Guru - Experienced User
What is the brand and model# of the ONT?
Try setting NAT Filter to OPEN on the XR router...
Farhad47 wrote:
Also i dont have a isp router/modem as i am using nighthawk xr1000 which is connected to a Fibre ONT on the wall which is conected from VLAN ID to my service- Farhad47Apr 13, 2022AspirantI already changed it from secured to open also its the Calix 801G v2 GigaPoint
