Farhad47
Apr 12, 2022Aspirant
XR1000 NAT type always moderate
Hi i just got the XR1000 but cant get my NAT type open on anything its always moderate i have tried WAN open from secured UpNP enabled/disabled Upnp disabled with manual port fowarding for Warzone but...
Farhad47
Apr 22, 2022Aspirant
Yes it set to always also tried set manually also auto setup...my download caps sometimes but upload doesnt at all i have tried speedtest.net and nperf tried factory reset updated latest formware i use VLAN id to connect and i have not tried DMZ i dont feel comfortable doing it incase i dont disable it properly but i dont see why it would need DMZ if it shows open on tplink without DMZ...also why do i get bufferbloat with nighthawk but none with tplink even tho my speeds are not capped on tplink...the only thing i noticed is on nighthawk i get extra 40mb on download/upload
Netduma-Fraser
Apr 22, 2022NetDuma Partner
VLAN is likely the reason the upload isn't working properly, that's something we're aware of. If you have the TP handle VLAN, then connect the XR to it and put the XR in the TP DMZ then upload will work and that should resolve the bufferbloat as well, maybe even the speed.
