-Skip
Jan 27, 2021Initiate
XR1000 Need to change the openvpn keys/certs
I'm looking for a way to update the keys and certificates in the openvpn config on the device. It wasn't listed in the model drop-down (too new?), but it's the XR1000 Nighthawk. I'm familiar with con...
Netduma-Fraser
Jan 27, 2021NetDuma Partner
As far as I am aware there is nothing you can do regarding that unfortunately.
- -SkipJan 27, 2021Initiate
Thanks that's what it looks like, just wanted to confirm. I'm really surprised they don't at least have a button for regeneration. The suggestions I've seen from support for comprimised keys is to change the port :smileylol:. Even just using the VPN means that I need to trust the initial generation and handling of the ones that are provided.
