eric22
Jul 06, 2024Aspirant
XR1000 Network lag issue got in game restrictions
Hello, Since few months I have been facing some lagging issues and connectivity issues with online gaming on console and pc, so I want playing more on my console series Xbox series X. Recently I got...
Jul 08, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
By the looks of the xbox configuration, the XR router is using a non default IP address pool, i.e. 10.0.0.x. Means that the default 192.168.1.1 has detected a conflict as the ISP modem or ONT already has a built in router. This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
Try option #2 first...
eric22
Jul 13, 2024Aspirant
HI,
Thank you for the reply, before few years when i bought XR1000 i had NAT strict with my xbox series x even with proper port forwarding so someone on this forum asked me to do this which resulted in in Nat open status.
This is what i did as described below :
Access the XR1000 Interface
Go to the System Information page
Find "WAN IP" in the center of the page
Copy the IP
Access the SFR Interface
Paste into IPv4 DMZ
Disable IPv6 DMZ
Btw as you said i can't access netgear OS by 192.168.1.1, its because my SFR Box (ISP) address is 192.168.1.1
Thats why my xbox has 10.0.0.x.
