SayYouWill
Jan 19, 2025Aspirant
XR1000 Nighthawk
After getting the router working (first time set up about a week ago), the internet connection is getting dropped. I have no explanation for it and there is no pattern for when it happens, and it is n...
Netduma-Fraser
Jan 20, 2025NetDuma Partner
In LAN Settings, set the DHCP range to start at .50, then assign reserved IP addresses to devices between .2 & .49 so they're out of the DHCP range, apply, reboot from the interface, wait 2 minutes and see if that stops the disconnects.
