dfg
Dec 29, 2022Tutor
XR1000 no internet access from guest network
Guest network does not provide internet access unless "Allow guests to see each other and access my local network" is enabled which makes guest network feature pretty much useless to me firmware ...
Netduma-Fraser
Dec 29, 2022NetDuma Partner
I've not seen any topics with this specific issue on the 1000, what devices are you seeing this problem with?
- dfgDec 30, 2022Tutor
All devices connected to guest network have no internet access, macbook pro and samsung galaxy s21, for instance
- Netduma-FraserDec 30, 2022NetDuma PartnerDid you factory reset after upgrading to the latest firmware? If not please do so and see if it works after that. A reset is recommended after an update to remove remnants of the previous version.
- FURRYe38Dec 31, 2022Guru - Experienced User
Looks like there maybe an issue with Guest Network, Apple and Android on the XR1000. I can't get my Galaxy Tab OS v12 to report a internet connection though it's connected to the XR1000:
FR was performed as well. Happens on both 2.4 and 5Ghz.
I can get my iPhone 12 Pro Max to connect and it gets internet, HOWEVER it takes about 1 full minute for the iphone to complete the connection to the router. The spinning circle next to the SSID name spins and spins for a minute before the circle turns to a check mark. Wifi Private IP address disabled.
Mac Book Pro 2018 OSX 13.2 (Beta) does the same thing it connects, reports no internet connection on the wifi icon, then about 1 minute later, that clears and showing a good wifi icon, however the mac book does not get any internet services.
I'll pass this onto NG for review.
