dfg
Dec 29, 2022Tutor
XR1000 no internet access from guest network
Guest network does not provide internet access unless "Allow guests to see each other and access my local network" is enabled which makes guest network feature pretty much useless to me firmware ...
dfg
Dec 30, 2022Tutor
Have just updated fw to version 1.0.0.64_1.0.49
Not sure what Mfr is
I've got optical terminal Raisecom and it works w/p i do have internet. The problem exists only in Guest network, meanwhile guest network concept is to provide internet access w/o access to internal network
michaelkenward
Dec 30, 2022Guru - Experienced User
Most modems/gateways/etc will have a label that says who made it and the model number.
The "optical terminal Raisecom" hints as at Optical Network Terminator (ONT). These rarely have an on board router.
