dfg
Dec 29, 2022Tutor
XR1000 no internet access from guest network
Guest network does not provide internet access unless "Allow guests to see each other and access my local network" is enabled which makes guest network feature pretty much useless to me firmware ...
Dec 31, 2022Guru - Experienced User
Looks like there maybe an issue with Guest Network, Apple and Android on the XR1000. I can't get my Galaxy Tab OS v12 to report a internet connection though it's connected to the XR1000:
FR was performed as well. Happens on both 2.4 and 5Ghz.
I can get my iPhone 12 Pro Max to connect and it gets internet, HOWEVER it takes about 1 full minute for the iphone to complete the connection to the router. The spinning circle next to the SSID name spins and spins for a minute before the circle turns to a check mark. Wifi Private IP address disabled.
Mac Book Pro 2018 OSX 13.2 (Beta) does the same thing it connects, reports no internet connection on the wifi icon, then about 1 minute later, that clears and showing a good wifi icon, however the mac book does not get any internet services.
I'll pass this onto NG for review.
dfg
Jan 03, 2023Tutor
To me it looks like a bug.
Are there any way to trace internal routing table or whatever? E.g. ssh and check some logs?
- Netduma-FraserJan 03, 2023NetDuma PartnerNo that isn't possible, FURRY has passed it on so hopefully it should be resolved for one of the next firmware iterations.
- FURRYe38Jan 08, 2023Guru - Experienced User
Looks like NG has a fix for this and hopefully be out in next official release.
đ
- edubs_ngMar 08, 2023Aspirant
I'm having this same issue. Where are you seeing that a fix is in the works and is there an ETA? I like to have all of my IoT devices on guest network, but I've had to move them all to the main network due to this bug. I had it happen once before but it resolved itself randomly and now it's back.
