dfg
Dec 29, 2022Tutor
XR1000 no internet access from guest network
Guest network does not provide internet access unless "Allow guests to see each other and access my local network" is enabled which makes guest network feature pretty much useless to me firmware ...
Jan 08, 2023Guru - Experienced User
Looks like NG has a fix for this and hopefully be out in next official release.
đ
edubs_ng
Mar 08, 2023Aspirant
I'm having this same issue. Where are you seeing that a fix is in the works and is there an ETA? I like to have all of my IoT devices on guest network, but I've had to move them all to the main network due to this bug. I had it happen once before but it resolved itself randomly and now it's back.
- FURRYe38Mar 08, 2023Guru - Experienced User
I think the user contacted NG support and asked about a beta that they were given.
