k1ngv
Apr 05, 2022Aspirant
XR1000 NO INTERNET
Hi! I have been having endless issues with the Wi-Fi connection to my XR1000. My current internet connection is NBN HFC through Aussie Broadband. The issues I am experiencing include "NO INT...
Apr 05, 2022Guru - Experienced User
Does the Internet LED turn amber when this happens?
Has a power off of the XR router for 30 seconds then back ON been performed?
k1ngv
The firmware of the Nighthawk XR1000 is V1.0.0.58 (latest update) - problem was occurring at previous firmware also.
The router is connected to the NBN ARRIS CM8200.
- Netduma-LiamApr 06, 2022NetDuma Partner
Thanks for confirming, could you please let me know if you factory reset the XR after upgrading the firmware? If not I'd suggest doing so.
Could you also please let us know if you require PPPoE, VLAN or DHCP identifiers to connect to the internet?
- k1ngvApr 06, 2022AspirantYes. Factory reset has been completed multiple times.
Also, require DHCP.- Netduma-LiamApr 06, 2022NetDuma Partner
Could you please go to Settings -> Setup -> LAN Setup and change the DHCP Starting IP address to 192.168.1.50.
Then, add a reserved IP address to the table at the bottom of that page for each device on the network struggling with connectivity.
Make sure each device is given an IP address between .1 and .49, such that they are not addresses included within the DHCP pool.
