Niico
Dec 03, 2021Aspirant
XR1000 not getting the correct speeds.
My nighthawk XR1000 is not getting the full speeds that my ISP provides. I have at&t fiber and I get 1000 up and down when im not using my XR1000. When I connect my router to my computer my download ...
Netduma-Fraser
Dec 04, 2021NetDuma Partner
The internet cable that you're using to connect the XR to the modem is limited to 100 Mbits, either this is because the cable itself is not capable of those speeds (needs to be Cat5e or higher) or the cable is damaged. If you replace it with a suitable cable you should see speeds more along the lines of what you usually get.
Niico
Dec 04, 2021Aspirant
bought a CAT6 cable and still have the same results
- Netduma-FraserDec 04, 2021NetDuma PartnerDoes the Device Manager still show 100Mbits for the internet port?
- NiicoDec 04, 2021Aspirant
Yes
- Netduma-FraserDec 04, 2021NetDuma PartnerWhat is the ISP modem/router model you're using? If you connect using the same cable from the modem does your PC get higher speeds?
