Refused
Jun 28, 2022Guide
xr1000 not limiting upload to device
Using a xr1000 firmware 1.0.0.64_1.0.49 windows 11
I'm having an issue with a Nanit baby monitor causing lag spikes while gaming. I've tried limiting its upload use in the QoS to 0.4 Mbps with upload share excess turned off, but it still spikes above 7Mbps.
- Netduma-LiamNetDuma Partner
Do you know if you currently require PPPoE, VLAN or DHCP identifiers in order to get a connection to the internet?
We have seen from a couple of other users that QoS is struggling to throttle upload when using one of the above methods for a connection.
- RefusedGuideI’m pretty sure it’s DHCP
As a test, could you set Congestion Control to 'Always', then run a third-party speed test.
Do the speed test results show upload as being throttled by Congestion Control or are they exceeding the limit?
