Matt6023
Aug 08, 2021Aspirant
Xr1000 orange light on lan
I cant get my router to connect to the internet, it has a solid orange light on for dsl, i have tried factory reset, resetting the modem its connected to and i cant access the router online to check f...
Matt6023
It is the one that my isp gave me,
Openreach bt,
United kingdom
Openreach bt,
United kingdom
Aug 08, 2021Guru - Experienced User
which one did the ISP give you? the label should have the model number.
Its more than likely a modem/router combo device. And it causes a double nat.
https://kb.netgear.com/30186/What-is-Double-NAT
Options? (only use 1)
1. put the netgears IP address into the ISP device's DMZ
2. put the ISP's device into modem only/passthrough mode
3. put the netgear in access point mode (half ruins the point of a gaming router)
- Matt6023Aug 08, 2021AspirantIsts an ECI,
THE MODEL NO. B-Focus V-2 FUb/r Rev B
