Matt6023
Aug 08, 2021Aspirant
Xr1000 orange light on lan
I cant get my router to connect to the internet, it has a solid orange light on for dsl, i have tried factory reset, resetting the modem its connected to and i cant access the router online to check f...
Matt6023
Ists an ECI,
THE MODEL NO. B-Focus V-2 FUb/r Rev B
Aug 09, 2021Guru - Experienced User
Not much info on that modem. Did you contact your isp about connecting a router to it?
That's where i'd start
- Matt6023Aug 09, 2021AspirantIt was working through it until i factory reset the rx1000
- michaelkenwardAug 09, 2021Guru - Experienced User
Matt6023 wrote:
It was working through it until i factory reset the rx1000I assume that you mean XR1000.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Pro Gaming Routers - NETGEAR Communities
However, I doubt if the support team behind DumaOS can do much about a clash between two routers. - Netduma-FraserAug 09, 2021NetDuma PartnerYou likely need to enter PPPoE details into the XR and then you should be able to get a connection
- Matt6023Aug 09, 2021AspirantOk,
How do i log on to the router without internet access?
