Matt6023
Aug 08, 2021Aspirant
Xr1000 orange light on lan
I cant get my router to connect to the internet, it has a solid orange light on for dsl, i have tried factory reset, resetting the modem its connected to and i cant access the router online to check f...
michaelkenward
Aug 09, 2021Guru - Experienced User
Matt6023 wrote:
The modem has openreach written on it but my isp is talk talk, could you recommend a modem to run the xr1000 through that is good?
TalkTalk is one of many ISPs in the UK that use the OpenReach network.
The modem you need depends on the service you have. TalkTalk and BT have a lot of customers on DSL connections. That comes in over the telephone network and is generally limited to ~70 Mbps.
Experienced users prefer using separate modems and routers. This gives them a much bigger choice in routers. Modem/routers rarely have the same choice of features. Nothing like the capabilities of your XR1000.
Modem/routers are also at the back of the queue when it comes to firmware updates for security and new features. Indeed, for most cable modem/routers there aren't firmware updates, because ISPs don't allow users or device makers to push out updates. And they rarely get round to it themselves.
The ideal DSL modem from Netgear is the DM200. But you may have a hard time finding one. When I needed a second one for my other line I had to go to the "open box" market. What I got looked suspiciously brand new, with all the bits of plastic protection you'd expect on a new device. I even paid about the same price that I coughed up for the first "official" one. They don't seem to be around now.
There are second hand DM200s out there. If they still work there is no reason why they should not soldier on.
You can buy new modem/routers. But these can cause problems. I dumped a D6400 because it took too long to negotiate an Internet connection that the router behind it times out, leaving me with a dead network. No problem if you are there when it happens, but a pain of there is a power cut when you are away.
Any "modem" that offers wifi is not modem only. It is a modem/router.
Perhaps the TalkTalk user community can offer some suggestions.
Matt6023
Aug 09, 2021Aspirant
Thank you
