Matt6023
Aug 08, 2021Aspirant
Xr1000 orange light on lan
I cant get my router to connect to the internet, it has a solid orange light on for dsl, i have tried factory reset, resetting the modem its connected to and i cant access the router online to check f...
Matt6023
Aug 09, 2021Aspirant
It was working through it until i factory reset the rx1000
Netduma-Fraser
Aug 09, 2021NetDuma Partner
You likely need to enter PPPoE details into the XR and then you should be able to get a connection
- Matt6023Aug 09, 2021AspirantOk,
How do i log on to the router without internet access? - Netduma-FraserAug 09, 2021NetDuma PartnerUse the IP address, 192.168.1.1
