JPayelle
Nov 22, 2021Follower
XR1000 password reset questions
I got a message trying to get into Dumos to recover my password put in the serial number. I put in the serial number, it ask for secret questions answers. I've tried all sorts of answers to those qu...
Nov 22, 2021Guru - Experienced User
Problem with the password recovery option is that if you didn't set it up, it still asks the questions but there isn't a correct answer.
So if you're password isn't working, and the password recovery isn't working, then you'd need to factory reset to get back in
