barnzey23
May 19, 2025Tutor
XR1000 pc login and mobile app issues
I have a XR1000 nighthawk router, was working fine but a few glitches resulted in me restoring to factory, since doing so my IOS app wont allow me to login, as it says "Logon timed out, please try ag...
May 19, 2025Guru - Experienced User
FYI: Nighthawk App Timed out Issue! | NETGEAR Communities
What browser are you using? Try MS Edge or Firefox after doing a full factory reset on the router. Be sure you clear out all web browser caches before going to 192.168.1.1 after the reset.
