barnzey23
May 19, 2025Tutor
XR1000 pc login and mobile app issues
I have a XR1000 nighthawk router, was working fine but a few glitches resulted in me restoring to factory, since doing so my IOS app wont allow me to login, as it says "Logon timed out, please try ag...
Netduma-Fraser
May 19, 2025NetDuma Partner
How did you perform the factory reset exactly? How long are you waiting after a reboot before trying to access again?
barnzey23
May 19, 2025Tutor
Held a pin to the back reset button of the router for 7-10 seconds, then had to set it up again via nighthawk app. But since setting it up it makes you login to the app and it says what I posted above continuously..
Well I last time I rebooted I waiting 5-10 mins before trying to login to the app
