egwok
Feb 14, 2022Tutor
Xr1000 Ping heat map cod COLDWAR is not listed
In ping heat map on xr1000 was the call of duty Cold War removed from the list for any reason cause it just disappeared on mine . It’s not on the list of the ping heat map I have tried factory reset a...
- Feb 15, 2022
Yeah Cold War was removed now that Vanguard is out. That being said, you can use the Vanguard/Warzone map for server information as they're pretty much exactly the same servers.
Netduma-Liam
Feb 15, 2022NetDuma Partner
egwok
Feb 18, 2022Tutor
Ok thanks thought I busted my router
