SmokeyOdin
Mar 30, 2022Tutor
XR1000 Port Forwarding UI Empty
Hi Everyone, I've just brought a new XR1000 (1.0.0.58_1.0.44) and I had setup my port forwarding stuff just fine, but now whenever I go to the page the list is empty, and creating new ones tells ...
Netduma-Liam
Mar 31, 2022NetDuma Partner
Does simply rebooting the router fix the issue? Try that if you haven't already.
If not, perhaps try accessing the interface from a new browser or incognito window and see if they're displayed there.
- SmokeyOdinMar 31, 2022TutorYeah I’ve tried all that even different browsers in case it was chrome or something, in the end I was forced to have to reset it and start again as I needed to fix the UI
- Netduma-LiamMar 31, 2022NetDuma Partner
Right OK, and is it now working better for you?
- SmokeyOdinMar 31, 2022TutorSeems to be at the moment but if it happens again I’ll give an update
