SmokeyOdin
Mar 30, 2022Tutor
XR1000 Port Forwarding UI Empty
Hi Everyone, I've just brought a new XR1000 (1.0.0.58_1.0.44) and I had setup my port forwarding stuff just fine, but now whenever I go to the page the list is empty, and creating new ones tells ...
SmokeyOdin
Mar 31, 2022Tutor
Yeah I’ve tried all that even different browsers in case it was chrome or something, in the end I was forced to have to reset it and start again as I needed to fix the UI
Netduma-Liam
Mar 31, 2022NetDuma Partner
Right OK, and is it now working better for you?
- SmokeyOdinMar 31, 2022TutorSeems to be at the moment but if it happens again I’ll give an update
- Netduma-LiamMar 31, 2022NetDuma Partner
OK thank you, yeah please do.
- bjenkins83May 05, 2022Aspirant
I have the same issue, I did a factory reset, everything showed up, and the ports worked, but about two minutes later the ports stop working and nothing shows in UI anymore. .
- SmokeyOdinJun 24, 2022Tutor
Just to give an update to this, restarted the router this morning and the problem is back, port forwarding list is empty and cant add ones that were there before.
- Netduma-FraserJun 24, 2022NetDuma PartnerThey are likely still enabled if you can't add them then and for some reason just not visible, as above definitely a good plan to make a ticket with NG
