SmokeyOdin
Mar 30, 2022Tutor
XR1000 Port Forwarding UI Empty
Hi Everyone, I've just brought a new XR1000 (1.0.0.58_1.0.44) and I had setup my port forwarding stuff just fine, but now whenever I go to the page the list is empty, and creating new ones tells ...
Retired_Member
May 11, 2022Hello, I regularly have the same problem.
When I happen to restart the router by cutting the power sometimes all the entries in my port openings disappear and no longer work however if I want to add them I have a message that an entry already exists and that there has a conflict.
At that time if I reset the router I can add the ports again but if I restore the backup again the list remains empty and I can no longer add the entries I have a conflict message.
Concretely, this is very problematic because as soon as my router crashes when opening the ports, it is impossible for me to restore the backup because each time the list remains empty and prevents me from adding again, as if the entries were present but not showing up or working.
Test in reset the same firmware, I had the same problem with the old firmware.
Clearly I think one can't back up hog open entries because when restoring from backup it never works.
Too bad for a product at this price to have to redo all the configuration at each reset
- Netduma-LiamMay 11, 2022NetDuma Partner
Have you tested the solution mentioned above where you upgrade the XR manually rather than using the auto-update feature? I'd suggest giving that a go and let us know how you get on.
- Retired_MemberMay 11, 2022
Same problem, impossible to add the entry despite it being empty, I had to reset the router and reconfigure everything....
- Netduma-LiamMay 12, 2022NetDuma Partner
Did the issue persist after that or does it appear to be OK now? Let us know.
