SmokeyOdin
Mar 30, 2022Tutor
XR1000 Port Forwarding UI Empty
Hi Everyone, I've just brought a new XR1000 (1.0.0.58_1.0.44) and I had setup my port forwarding stuff just fine, but now whenever I go to the page the list is empty, and creating new ones tells ...
Netduma-Liam
May 11, 2022NetDuma Partner
Have you tested the solution mentioned above where you upgrade the XR manually rather than using the auto-update feature? I'd suggest giving that a go and let us know how you get on.
Retired_Member
May 11, 2022Same problem, impossible to add the entry despite it being empty, I had to reset the router and reconfigure everything....
- Netduma-LiamMay 12, 2022NetDuma Partner
Did the issue persist after that or does it appear to be OK now? Let us know.
- Retired_MemberMay 12, 2022
It's ok now but I know it will start again
- Netduma-LiamMay 13, 2022NetDuma Partner
Let us know if it does, it may be something to raise directly with NETGEAR at support.netgear.com. Unfortunately as a member of the Netduma team, we don't have too much control over the NETGEAR settings.
