SmokeyOdin
Mar 30, 2022Tutor
XR1000 Port Forwarding UI Empty
Hi Everyone, I've just brought a new XR1000 (1.0.0.58_1.0.44) and I had setup my port forwarding stuff just fine, but now whenever I go to the page the list is empty, and creating new ones tells ...
Retired_Member
Aug 01, 2022Yesterday another concern, but then there that makes me seriously angry.
The router suddenly restarted, but I didn't notice it, it's as if it had reset, with the default login / pass, except that it put the 5G and 2.4 networks G open without pass, free access to all neighbors......
Honestly hats off to security for a router at this price!
What to be angry all my network accessible to everyone.
Then after restarting everything came back halfway, and this time again the problem with the translate ports, so I'm going to have to reset the whole router and reconfigure everything because if I restore the settings I still have the same translate port problems.
Netgear customer for years, all my networks, nas are of this brand, but I have never seen a device of this range (and at this price!) so bad, frankly disappointed and angry..
I believe that Netgear should go through here and take the problem of this device seriously, or stop selling it, because in view of the messages they will lose a lot of customers because of this device.
Me first.
Netduma-Fraser
Aug 01, 2022NetDuma Partner
So it was definitely a reboot and not a reset, you didn't get the setup wizard when you accessed the interface? If you're having issues and make a backup then when you go to restore from that backup at a later date there is a possibility you will restore the issues you had previously. I would suggest you get a replacement as that is not something that should happen when rebooting or restarting so it's definitely faulty.
