SmokeyOdin
Mar 30, 2022Tutor
XR1000 Port Forwarding UI Empty
Hi Everyone, I've just brought a new XR1000 (1.0.0.58_1.0.44) and I had setup my port forwarding stuff just fine, but now whenever I go to the page the list is empty, and creating new ones tells ...
Retired_Member
Aug 01, 2022I had the wizard, but it was behaving weird, I only did half of the steps then got to the interface, had to reconfigure.
I restored a configuration of the parameters that had been done clean after a hard reset, then I found the problem of this original post with port translations
Netduma-Fraser
Aug 01, 2022NetDuma Partner
Thanks for clarifying, I would suggest making a ticket with NG directly to get a replacement/RMA http://support.netgear.com/
