SmokeyOdin
Mar 30, 2022Tutor
XR1000 Port Forwarding UI Empty
Hi Everyone, I've just brought a new XR1000 (1.0.0.58_1.0.44) and I had setup my port forwarding stuff just fine, but now whenever I go to the page the list is empty, and creating new ones tells ...
Retired_Member
Sep 23, 2022Yesterday power down, on reboot, again same problem, empty list, but impossible to add port openings it puts a conflict, the problem is clearly not hardware but software....
Netduma-Fraser
Sep 23, 2022NetDuma Partner
Did you make a ticket with Netgear? What did they advise?
- Retired_MemberSep 25, 2022
I just contacted Netgear, he should come here more often.....
