Geiokami
Mar 15, 2022Aspirant
XR1000 Port forwarding ui glitch
I got a Nighthawk XR1000 from my isp, when trying to forward ports it only sometimes actually goes through but when i try to edit or delete one the ui will glitch and edit/delete the entry above it. ...
Mar 15, 2022Guru - Experienced User
Whos your ISP?
- GeiokamiMar 15, 2022Aspirant
What Firmware version is currently loaded? 1.0.54.10_5.0.11
Whos your ISP? Grande communications
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Arris Touchstone CM8200AAs above, also what device and web browser are you using to make the changes? tried on 4 different computers and a phone.
- Netduma-FraserMar 15, 2022NetDuma PartnerCould you disable Armor from the app if you have it enabled and then try again please?
Dont have the subscription.
