Geiokami
Mar 15, 2022Aspirant
XR1000 Port forwarding ui glitch
I got a Nighthawk XR1000 from my isp, when trying to forward ports it only sometimes actually goes through but when i try to edit or delete one the ui will glitch and edit/delete the entry above it. ...
Geiokami
What Firmware version is currently loaded? 1.0.54.10_5.0.11
Whos your ISP? Grande communications
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Arris Touchstone CM8200A
As above, also what device and web browser are you using to make the changes? tried on 4 different computers and a phone.
Netduma-Fraser
Mar 15, 2022NetDuma Partner
Could you disable Armor from the app if you have it enabled and then try again please?
- GeiokamiMar 15, 2022Aspirant
Dont have the subscription.
- Netduma-LiamMar 16, 2022NetDuma Partner
I believe you'll still need to go to the App and double-check it's disabled, it can still have an affect.
