longr5310
Aug 24, 2023Aspirant
XR1000 Pro Gaming Router DUMAOS WIFI 6 Router
I cannot understand why Madden is not listed in the ping heat map drop down menu?! I'm pretty much stuck with the games that load in the ping heat map drop down box... most games that i don't play. T...
Netduma-Fraser
Aug 24, 2023NetDuma Partner
Ping Heatmap just pings servers, it doesn't do anything other than that, it wasn't always a feature so you can still benefit by using the Geo-Filter and putting the location over your region to still get a great ping. I can make a request for the team to get it added to Heatmap.
- longr5310Aug 24, 2023Aspirant
Ok do I need to do a factory reset to obtain the feature you are referencing?
- Netduma-FraserAug 24, 2023NetDuma PartnerWhat feature exactly? Ping Heatmap and the Geo-Filter you already have access to as you mentioned
- longr5310Aug 26, 2023Aspirant
Sorry for the confusion, I am referring toto the wrong thing. The traffic priority in QoS. Games are not listed there like Madden 24, etc. How do we get the games we want so we can select them? I have tried game console etc was looking for the game i can select. I tried the frostbite engine setting for Madden 24 since Madden is powered by Frostbite however I do not get download and upload packets registering in traffic prioritization so the frostbite setting did not work.
