longr5310
Aug 24, 2023Aspirant
XR1000 Pro Gaming Router DUMAOS WIFI 6 Router
I cannot understand why Madden is not listed in the ping heat map drop down menu?! I'm pretty much stuck with the games that load in the ping heat map drop down box... most games that i don't play. T...
longr5310
Ok do I need to do a factory reset to obtain the feature you are referencing?
Netduma-Fraser
Aug 24, 2023NetDuma Partner
What feature exactly? Ping Heatmap and the Geo-Filter you already have access to as you mentioned
- longr5310Aug 26, 2023Aspirant
Sorry for the confusion, I am referring toto the wrong thing. The traffic priority in QoS. Games are not listed there like Madden 24, etc. How do we get the games we want so we can select them? I have tried game console etc was looking for the game i can select. I tried the frostbite engine setting for Madden 24 since Madden is powered by Frostbite however I do not get download and upload packets registering in traffic prioritization so the frostbite setting did not work.
- Netduma-FraserAug 26, 2023NetDuma PartnerWhat platform are you playing on? Regardless of the game Games Console should work, if you're using a console that is the option you should pick also. We can update it over the cloud, I've already put a request in for that.
- longr5310Aug 27, 2023Aspirant
PS4 is the platform.
