Rome916
May 30, 2023Aspirant
XR1000 QOS for gigabit
So I have Xfinity internet with 1200 download and about 40-43 upload. I live in a smart home so I usually have 25 plus devices connected to the internet with only 4-5 of them being inactive on the net...
Netduma-Fraser
Jun 02, 2023NetDuma Partner
Specifically use PingPlotter from the guide I linked, it will give you a more accurate representation
Rome916
Jun 02, 2023Aspirant
I see. I read the guide you linked and it said to completely saturate my connection. The thing is I have so many devices in my household. I’m kinda too lazy to go around and bother everyone and be like “hey watch a hd movie on your phone or computer or tablet”. So I was wondering if I just saturate my connection with my desktop and my phone. Will it still help?
- Netduma-FraserJun 02, 2023NetDuma PartnerYou don't need every device to be active, a big download and a stream or two should be sufficient from the device you're using. Downloads use as much bandwidth as they can get their hands on.
- Rome916Jun 03, 2023AspirantUpdate I still feel this weird lag. Not ping wise but jitter wise. Shots seem to not register. I feel like I’m always behind on an enemy on the server even when they have higher ping and movement seems to be so sluggish. I still believe it’s because I’m getting bufferbloat spikes. I read that the xr1000 only handles up to 25 devices and having a smart home with smart lights, smart alarm system, cams, smart tvs, tv top boxes, iPads, iPhones, desktops etc… the QOS on the xr1000 can’t handle it. Seems like I might have to switch to asus software for QOS but I’ll patiently wait for duma 3.3. Really love your guys’ software. Really do. But it seems like I have to mess with QOS almost every single day
- Netduma-FraserJun 03, 2023NetDuma PartnerNot sure where you read that but that's inaccurate, it's capable of handling a lot more. Try now forcing servers that are slightly further away, that can sometimes give a better experience if they're more stable.
- Rome916Jun 03, 2023AspirantI must’ve read it wrong. I just checked and it said 25 plus. But I don’t know what can be the issue. I know I have to connect every device that uses Wi-Fi but we have an iMac that we don’t use that’s connected and a smart tv that we don’t use but still connected to the Wi-Fi. I’ve tried almost everything to get an optimal performance for gaming but it just seems the QOS doesn’t perform well with my connection. I had an isp tech come over and look over my coax cables and everything and to his investigation. Everything was on par. I don’t know if it’s because I have one too many devices on network but this seems to just make gaming not enjoyable anymore. Too much aggravation if I knew he should’ve died. Why aren’t my bullets registering. My next theory is that even tho I have such a high speed connection. I should probably set my QOS to like 800-35 instead of my actual average speed which is 944-42. Or I should just put my max speeds which is 1.2gb-42mb. But given the xr1000 doesn’t support anything over 1 gig. I should maybe put it at 1g-42mb. Idk but I’ll keep experimenting. Also what algorithm does the duma QOS use. Like cake or codel. Or duma has their own exact algorithm for it. I heard fq_codel is one of the best algorithm.
- Netduma-FraserJun 03, 2023NetDuma PartnerWhat is your experience like if you connect direct to the modem? I would suspect it would be better without other devices using bandwidth but if not that would indicate an issue the router isn't able to resolve. Do try forcing servers further away as a lot of people try that with good success. FQ_Codel plus our own algorithm.
- Rome916Jun 03, 2023AspirantWell when I had my isp modem/ router all in one. My gameplay was a lot worse with all devices connected to it. But the current modem I have is just a modem and it is not capable of producing Wi-Fi. Would you suggest me to just buy a modem that is Wi-Fi capable and produces internet and ditch the xr1000?
- Rome916Jun 03, 2023AspirantMind you my modem is the nighthawk cm2050v with built in automatic QOS. Idk if that would be interfering with the xr1000 QOS
- FURRYe38Jun 03, 2023Guru - Experienced User
FYI, the CM series modems do not have QoS features. Yours just has voice features for phone support.
I would recommend a CAT6A STP cable between his modem and the XR router as well.
- Rome916Jun 03, 2023AspirantI have a cat 8 rj45 shielded cable running from the modem to the xr1000 wan
- Netduma-FraserJun 03, 2023NetDuma PartnerNo that's not what I would suggest, I just want to see if you have the same issue. That would be a perfect test then to connect your gaming device direct to the modem instead of the XR, no other devices can possibly affect it and then you can see what the experience is.
- Rome916Jun 03, 2023AspirantWell I did try this. I once disconnected all my devices and connected my pc directly to the modem and my gameplay was amazing. Too bad i couldn’t use this set up because my devices need to be on the network as well.
- Rome916Jun 03, 2023AspirantOnly thing that sucks is my modem has one lan port and that’s how I use it to connect my xr1000 to the internet.
- Netduma-FraserJun 03, 2023NetDuma PartnerModems can only pass internet through to one device. Okay so it probably is related to your devices/settings. Have you tried forcing other servers yet?
- Rome916Jun 03, 2023AspirantWon’t be able to till I’m back in town this Monday but I believe it is my settings. I just don’t know what to do at this point. Duma is so buggy on the xr1000
- Netduma-FraserJun 04, 2023NetDuma PartnerOkay keep us posted, if those changes don't help I'm sure we can think of some other things that may help, if not the new firmware shouldn't be far off now.
- Rome916Jun 05, 2023AspirantSo far no help even with long distance servers. Tried almost everything so I don’t know what could be making my bufferbloat spike so much. Do you have any idea when the new duma firmware will be out for the xr1000? Any estimated release date?
- Netduma-FraserJun 05, 2023NetDuma PartnerWe don't give out any ETAs but it shouldn't be much longer. We'll be doing a big DPI update as well soon which may actually help as well.
- Rome916Jun 05, 2023AspirantI hope it is soon. Now currently I am looking at the asus GT-AX11000 pro. I’ve seen really good reviews for it’s QOS ability but I’m still having high hopes for the XR1000. I really want to love your guys’ duma software but so far it has been a huge let down on my end. I don’t know if it’s because I have too many devices the xr1000 can handle or it’s just the software itself. All I know is I’m just left bamboozled with a QOS mess
- Netduma-FraserJun 05, 2023NetDuma PartnerAre you using IPv6, PPPoE or VLAN? If so that could be causing QoS to not be as effective which might explain the problem
- Rome916Jun 05, 2023AspirantI’m using dhcp as I have a cable connection with Xfinity and no I have ipv6 turned off.
- FURRYe38Jun 06, 2023Guru - Experienced User
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Rome916 wrote:
Mind you my modem is the nighthawk cm2050v with built in automatic QOS. Idk if that would be interfering with the xr1000 QOS - Netduma-FraserJun 06, 2023NetDuma PartnerIt might be best to factory reset and just make changes to Congestion Control without changing anything else out of the ordinary to see if it's a misconfigured setting
- Rome916Jun 06, 2023AspirantI actually did try that before I came to these forums. But for now I will shelf my xr1000 until the new duma firmware comes out.
Can you please post the two log pages for the CM modem so we can review that please. Lets make sure the modem is to spec.
