manpeewee93
Apr 12, 2025Initiate
XR1000 QoS Not Working
My QoS is not working on my XR1000. I've tried factory reset and still the same thing. When I click on it, it says device not found. I don't know what that means.
What did you do to get it working (so the next person knows)?
And then you might want to mark that as the answer so it highlights at the top
- manpeewee93Initiate
I finally got it to work. thank you!
- Netduma-FraserNetDuma PartnerThere are only 2 ways to resolve this error:
Factory Reset (either from the interface or by holding the RES button in the back of the router for 30 seconds)
Re-connect the device that you deleted from the Device Manager back to the router via the same connection method (ethernet, 2.4GHz or 5GHz), give it the same device type and name. Then the error will disappear.
Other than that can you clarify what you mean by QoS not working exactly?
