mocha__
Jan 22, 2024Aspirant
XR1000 QoS Upload still not working with no solution
its been like 4 years since the release of this router and lots of problems i will say but in particular im talking about QoS Upload in general. my fttp ADSL connection offers a PPPOE connection but ...
Netduma-Fraser
Jan 29, 2024NetDuma Partner
That is really weird, don't think I've seen that specific issue before, is it on a third party speedtest you're checking this?
mocha__
Jan 31, 2024Aspirant
its the same result on any speedtest i do. i thought this was a PPPOE issue cause i experience the same issues as others with the upload not capping.. but at least now i found a way where it can somewhat work lol.
my ISP is a fttp 30mbps download, 5mbps upload. they use a Calix ADSL modem. they do have a PPPOE page with a username and password but my routers always automatically connect DHCP anyways. interested to know what in the UI or settings of the XR1000 that is bugging because ive used other routers where it has no issue capping my upload
- Netduma-FraserFeb 02, 2024NetDuma PartnerIs Bandwidth Allocation set to Applications or Devices and does it happen regardless of that option? Do you have any custom Traffic Prioritization rules enabled?
- mocha__Feb 02, 2024Aspirant
yes it happens on both, and the traffic rules dont bug it out. whether i have some or not, qos works fine. its only the bandwidth allocation part and anything in that section. no matter what i try to change there, it will uncap the upload until i reset distribution. so right now i just put the CC sliders and use traffic rules. ive done lots of testing on this router since ive had it and its the first time tftp worked good cause qos actually works now. before it would never work no matter what i did
- Netduma-FraserFeb 03, 2024NetDuma PartnerOkay I think we'll probably have to look into that as I can't think of anything currently that would cause that to happen
