JesteryJeff
Feb 13, 2021Tutor
XR1000 Random reboots\ disconnects with USB attached
As the title suggest I am having problems with my XR1000 rebooting and disconnecting devices out of the box. I'm running the latest firmware 1.0.0.52_1.0.38 . The only time this happens is when a dev...
Netduma-Fraser
Feb 14, 2021NetDuma Partner
This could insinuate that it is taking to much power, 12TB is pretty hefty! Do you have the router connected directly to a power outlet or through an extender? If an extender try direct to the wall and see if that resolves the issue.
- JesteryJeffFeb 14, 2021Tutor
The router is plugged directly into a wall AC outlet. The Harddrive also has its own power source if that is what youre asking. i would assume if it were a power thing the device would stop responding when i first plug it in and it's demanding the most power. Actuallly thinking about it, it might be when it puts the device to sleep due to inactivity?
- Netduma-LiamFeb 15, 2021NetDuma Partner
That could well be the problem, is there any possibility that you can configure the external drive to not go to sleep after a certain amount of time of inactivity?
