seanwilks
Jan 07, 2022Follower
XR1000 router is preventing Citrix Receiver app from launching.
This is a strange issue and reproduceable on multiple PCs on my LAN. I have a computer that uses a VPN client to connect to work network, and the local PC connects using RDC to a PC at work. From the...
nielsvds
Jan 07, 2022Luminary
The Nighthawk pro gaming router do have build security from BitDefender and other security features called net armor. Chances are high that it is blocked there. The traffic controller can block it. Did you create any blocking rules? How to configure armor you find in the manual starting from page 91. The ports that need to be opened you find here (Citrix Workspace app = receiver): https://docs.citrix.com/en-us/tech-zone/build/tech-papers/citrix-communication-ports.html
