Kapuaiterangi
Aug 22, 2024Aspirant
XR1000 router login and firmware not working
Hey all,
Any idea on how to fix my XR1000, anytime we have a power cut the router fully resets to "NETGEAR & NETGEAR 5G". Worst still is opening the wifi removing any passwords, essentially opening up newtork for anyone in the area to use.
The app is about as useful as a wet paper bag as putting passwords back on, just result in a frozen screen.
But it's now resetting without a powercut. I checked my router last time I could actually get in via web and it said there was no update. But i found one on the Netgear website but its downloaded as a .chk file and opens in note pad and nothing else.
Any advice this is getting exhausting. Or Im just a noob who should've stuck to the cheap routers from IP lol
You don't open the firmware file. You upload it to the router.
here's a video of how to do it. Starts about 3:45 in.
https://www.youtube.com/watch?v=uC8L7HaR2gw
- KapuaiterangiAspirantI can't get into the Dumo interface, IP address in search bar isn't working and neither 🥴
Factory reset the router and set up from scratch using a wired PC and web browser?
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
- Netduma-FraserNetDuma PartnerAs above for upgrading but setup everything then reboot the router via the interface, this should act as a hard save and prevent it resetting upon loss of power.
