LaggyDaWifi
May 15, 2024Aspirant
XR1000 settings get wiped on factory reset
Hey, I just want you to know that if you factory reset your router and you saved that config file, your settings won't save if you choose to restore the settings, i had to reconfigure my whole SSID &...
May 15, 2024Guru - Experienced User
If you had WiFi Settings configured prior to the back up configuration file being generated and saved to file, restoring should bring those back after a factory reset and restore operation.
- LaggyDaWifiMay 15, 2024Aspirant
I had my settings back up before I saved the file, I had to reconfigure my Wi-Fi settings after I factory reset!
- FURRYe38May 15, 2024Guru - Experienced User
So after you reset and applied the backup config from file, the custom wifi settings were not re-applied?
Correct, they were not re-applied
