fatalbert
Nov 28, 2021Tutor
XR1000 settings get wiped on reset
Whenever I reset my XR1000 router (pushing the button on the back of it) the settings appear to get wiped and I am back at factory new settings and need to set everything back up. I've tried backing ...
- Nov 28, 2021Once you setup the router, reboot from the interface and wait 2 minutes before accessing. This will act as a hard save, then if you use the button to reboot it next time your settings should be preserved.
Netduma-Fraser
Nov 28, 2021NetDuma Partner
fatalbert
Nov 28, 2021Tutor
I will try this and get back to you.
