fatalbert
Nov 28, 2021Tutor
XR1000 settings get wiped on reset
Whenever I reset my XR1000 router (pushing the button on the back of it) the settings appear to get wiped and I am back at factory new settings and need to set everything back up. I've tried backing ...
- Nov 28, 2021Once you setup the router, reboot from the interface and wait 2 minutes before accessing. This will act as a hard save, then if you use the button to reboot it next time your settings should be preserved.
Netduma-Fraser
Nov 28, 2021NetDuma Partner
fatalbert
Nov 28, 2021Tutor
That seemed to have done the trick. Would be nice if the settings were saved when you hit save after changing them and not only after resetting through the interface. Seems odd, but it worked. Hopefully it stays this way.
