charleyshf
Jul 01, 2022Tutor
XR1000 shows pc(s) always offline ?
Hello! So I have the most recent firmware on my XR1000, I did a factory reset after the recent firmware update. The problem I have been having lately is that I have my pc which is set to a static...
charleyshf
Jul 01, 2022Tutor
I shutoff my pc when i'm done for the day. Next morning pc is started up and running, but the router does not show it as online. I can run speedtest multiple times, download large files, it does not show up at all.
Netduma-Fraser
Jul 01, 2022NetDuma Partner
The other devices you’re using are they in standby? Do you use Wake On LAN for the PC? Double check the other devices on the Device Manager do any of them have the IP that the PC itself says it has?
- charleyshfJul 01, 2022Tutor
None of my equipment uses wake on lan or standby mode. I did double check to make sure that the ip is not used anywhere else.I also tried a different IP address just in case, and the same thing happens which is really odd.
Is there something else that would block my pc from being included in the network monitor?
- Netduma-FraserJul 01, 2022NetDuma PartnerCould you remove the static IP please and then see if it appears online without the reboot?
I deleted the static ip, did not reboot and now I can see my pc in the network monitor?
