vegastrucker702
Aug 14, 2021Guide
XR1000 slow ethernet speed
I recently “donated” my XR500 to my son (different household) and bought myself the XR1000. I have tried everything I have seen mentioned in other threads in here- even the Netgear speed guide, and ev...
- Aug 21, 2021So you should be able to turn this off using the Nighthawk App on your phone in the settings, then reboot from the app, wait 2 minutes before accessing and see if the speeds are improved
Netduma-Fraser
Aug 15, 2021NetDuma Partner
There is actually a newer firmware just released than the one you're on - .58, I'd recommend you do the check again to upgrade to that, once completed do a factory reset from the interface. Then see where you're at with the speeds and we can go from there
vegastrucker702
Aug 15, 2021Guide
Thank you, I will try that and let you know the results
